am i getting hd sound?
possibly prof, but what got me thinking is that when i switch between the standard dd or pcm soundtrack and the true hd or dts ma one on the same disc, when using my bdp to output to my stereo amp, i can hear the difference.(have not tried this with the dac yet)
for example with the dark knight, the dd soundtrack is louder than the true hd one, as i often found to be the case with other movies, when i had the full 5.1 set-up.
would i notice this difference if downmixing the hd sound equated to standard pcm?
i'll experiment a bit and report back anyway
jiggyjoe
9
Dolby TrueHD may be transported to AV receivers in 5.1 or 7.1 channels, at lossless quality, in one of three ways depending on player and/or receiver support.
  • Dolby TrueHD-capable players can create a 2-channel (stereo-compatible) downmix from a 6-channel source.(which is what you are doing now Maxflinn)
  • Deliver audiotrack Over 6 or 8 RCA connectors as analog audio, using the blu-ray player's internal decoder and digital-to-analog converter (DAC).
  • Over HDMI 1.1 (or higher) connections as 6- or 8-channel Linear PCM, using the blu-ray player's decoder and the AV receiver's DAC.
  • Over HDMI 1.3 (or higher) connections as the original TrueHD bitstream, with decoding and DAC both done by the AV receiver.
professorhat
992
22
18,895
maxflinn:
I would say it's highly likely that the the Dolby TrueHD-downmixed stereo PCM soundtrack would be less compressed than the Dolby Digital-downmixed stereo PCM soundtrack. So choosing the different soundtracks should highlight that difference.
As I said in my original post, the issue comes down to terminology - is what you're getting "HD audio" - not the in the true home cinema sense as you're not getting all 6 (or 8) channels of the soundtrack. However, the downmixed stereo output of a Blu-ray should be higher definition when compared to a DVD's downmixed stereo output.
It's also worth noting that some Blu-ray discs will likely come with a dedicated PCM stereo soundtrack which will have been authored directly in the studio for optimum stereo playback. So your experience will be different with different Blu-ray discs as well. This is more likely with music Blu-rays.
jiggyjoe:
cheers jiggyjoe, i'll check out some of those links later
professorhat:maxflinn:
yup, that all makes good sense as usual prof
. thanks for your input, i must have a look for any dedicated pcm stereo soundtracks in future
ASK THE COMMUNITY
