Jota180 said:Speakers are the component that have the most varied sounds between makes and models. A good hi fidelity amp should just add gain to the input signal and nothing else or it falls short on fidelity. The biggest difference in source is from CD masterings and not CD players. Crap CD's are crap no matter what you play them in.
If you want to arse around with tone controls which negatively impact on fidelity then can I ask why are you in the market for HIFI (high fidelity)? Maybe better off buying a Sonos or some other cheerful system.
[/quote
Please don't take the thread down this rabbit hole. Tone controls are perfectly acceptable to use if desired and some of the top names in HiFi include them. To each his own.
davedotco said:I think the trick here is to work out what it was in the McIntosh/Sonus Faber system that was really making the difference.
I have spoken about this before, but i think that some equipment, often but not always amplifiers, are just so much better than the norm that they make systems sound really special.
There is, to my ears, a general mediocrity that overlays much modern equipment, and most systems. There is nothing wrong as such, just an overwheming feeling of, well, averageness. Hard to explain as a lot of people simple do not hear what I am describing, but from time to time we here from someone like the OP who have suddenly been exposed to a really good setup or sometimes, someone new to the hobby who finds that the equipment he is being told is great, thrilling etc, finds it nothing of the sort.
Clearly a lot of this equipment is pretty expensive, some frighteningly so but there are systems that can be put together at reasonable cost that do things very differently from, even highly rated, mainstream product. Finding it of course is the difficult bit, a good dealer will help immensly.
npoguy said:Jota180 said:Speakers are the component that have the most varied sounds between makes and models. A good hi fidelity amp should just add gain to the input signal and nothing else or it falls short on fidelity. The biggest difference in source is from CD masterings and not CD players. Crap CD's are crap no matter what you play them in.
[/quote
Tone controls deviate from hi fidelity.
A wind up record player is also perfectly acceptable to use too but it's not hifi.
npoguy said:Unless you're lucky enough to have an acoutistically treated room, just about everything in our listening rooms works against having a true "high fidelity" experience! For some people, tone controls allow them to get a bit of it back.
npoguy said:Dave,
Sorry, I probably overstated that a bit to make a point about the earlier statement regarding high fidelity. Whether it's a different amp, cables, speakers or tone controls we're all in search of that certain "something" and felt the reply was condescending.
robbo400 said:was intending to ideally get an amp with multiple speaker outlets or a spwaker witch box. Ideally the first, as any negative impact on sound would only affect the other 2 rooms which is less important to me.
My current Sansui 8080 has 3 speaker outputs so that would be my dream but I don't think that exists in any new amps
robbo400 said:"Find the biggest, best integrated you can find that has tone controls and A/B speaker switching."
Guess that would either by McIntosh, Luxman or Accuphase?
Agree with your set-up suggestion...exactly what I had in mind.
Re Sonos, I am sure you are right, that direction is just not for me...
davedotco said:robbo400 said:"Find the biggest, best integrated you can find that has tone controls and A/B speaker switching."
All have fantastic reputations though I doubt any are that easy to audition.
Native_bon said:From threads like this hope hifi manufacturers are taking note. Seems people realising most hifi out there are just ot up to standard. More reason I got my self a boston acoustics. I find most of the british speakers too bright and lacking in bass.
