all in one boxes
Hi.
am doing some research into surround sound systems for my parents (they think i know everything about home entertaiment because i am into hifi!)
Budget isnt great, maybe £ 300 - £400, and so far all in one boxes ( dvd player and speaker package) look like quite a good option.
Are they any good? Is anyone able to explain how it works? Do they have an internal amp? Are you able to channel the tv through them for when not watching dvd's??
Thanks for any replies!
Just188:
Hi.
For that price range it's your best/only option. Unless you go second hand. The dvd player has the amp built in and everything is connected to it. Normally five speakers and a sub are also included in the box. If your parents have not had a surround system, I'm sure they will be very pleased with what they get. You will be able to connect the tv to it via hdmi, component or scart.
http://www.petertyson.co.uk/ebuttonz/ebz_product_pages/pioneer_dcs580.shtml
or if you want wireless rear speakers (a bit more playing about)...
http://www.soundandvision.co.uk/dvd/dvd-home-cinema-systems/sony-dav-dz860w
Or if you want smaller speakers....
http://www.amazon.co.uk/Sony-DAVIS10-Compact-Channel-Cinema/dp/B000V9F532
