Hello again, fellow forum members.
Having recently purchased an Apple Tv, which is connected through my dacmagic and to my speakers I found the sound quality a bit worse than when my macbook is connected to my dacmagic via optical using the same cables. The sound is a bit bright and I'm missing some tight bottom end. Anyone else have this issue? Can you also tell me that if I were to better the Apple Tv using a streamer, is it possible provided that I use the dacmagic? It is my opinion that more expensive streamers sound better simply because they use more expensive dacs. If you remove the dac from the equation I reckon a wireless streamer as a transport doesn't make that much of a difference. Thoughts and arguments absolutely welcome.
Cheers,
Shafin
Cheers,
Shafin
