My setup is a mid 70s one (except the Marantz) consisting of ; Rotel RA612 Amp - Pioneer PL112D T/table - Marantz CD48 - pair of KEF 104ABs
One of my speaker channels on the Rotel has blown and i'm fitting new tweeters to the KEFs which I like very much. I'm looking to purchase a new amp and a second pair of speakers which will be used as the main pair and put the KEFs at the back, my head is spinning with looking at all of your recommendations and I don't no which I should think of buying!, so your advice would be welcome. My music taste is wide, from 60&70s all the way to jaz, opera and classical. My budget is around a £1000 (I can go more) My room size is 7 x 3.8mtrs. I also run the TV thru the amp when there is any music, like the proms on. Also your views on a new CD player and Turntable which I'll probably update at a later stage.
Thank You
Thank You
