havent met an amp yet i haven't overheated, and i have a small room...but i am a special case. Even overheated active speakers...BenLaw said:FWIW, ATC are class A up to two thirds of their max power. Other than in a concert hall, I can't imagine anyone getting to that point. So they're effectively class ACnoEvil said:If you like the Sugden (which is class A), and supurb at presenting the types of music that you have mentioned, then you are unlikely to settle for anything that isn't class A. There is no active speaker, that I'm aware of, that uses this type of amp - it often uses class D, as it produces a lot of power from a small size.![]()
The best advice I'm prepared to offer, with your budget, is go and audition few different brands.nk1982 said:Hi all
This is my first post on these forums so please forgive me if I break any rules/etiquette![]()
I have been saving for a while with the idea of buying a hi-fi to use to listen a variety of different styles of music from Classical and Jazz through to Indy/Acoustic. We currently live in a mid-floor flat in a victorian conversion which means that we rarely listen to music at high volumes, and so we're really looking for something that can sing at lowish volumes. Ideally it could also be listed to at greater volumes if we move to somewhere more accomodating but we're never going to need huge power.
We currently have most of our music stored on CD and lossless on hard drive so are fairly flexible around the choice of source, but ideally we would like any set up to have a good DAC and digital inputs so that it will be reasonably futureproof.
We did listen to a couple of set ups a few years ago including Naim 5 cd player and amps, a Naim SuperNait, and a Linn based streaming streaming set up (can't remember the exact one) but none of them really blew us away and none really seemed to deliver great sound at low volumes. In terms of budget I think it all depends on how impressed we are with it but I think around £5-7k is the most my wife will ever let me spend so that's a top end.
Thanks in advance for any advice.
Nick.
I'd like to see that happen...BenLaw said:FWIW, ATC are class A up to two thirds of their max power. Other than in a concert hall, I can't imagine anyone getting to that point. So they're effectively class ACnoEvil said:If you like the Sugden (which is class A), and supurb at presenting the types of music that you have mentioned, then you are unlikely to settle for anything that isn't class A. There is no active speaker, that I'm aware of, that uses this type of amp - it often uses class D, as it produces a lot of power from a small size.![]()
those Valdus speakers must be true monsters. if I were you I'd checked their impedance and phase angle plots (hopefully the manufacturer can supply this. they should...). I suspect a stable amp into 2 Ohm loads is a must. and an Arcam is not a good pick for the job, I'm affraid. you like it loud? so you should look for something in those lines: 200Wpc into 8 Ohms -> 400Wpc into 4 Ohms -> 800Wpc into 2 Ohms (but this trick can only well engineered amps pull. you should wish for at least 600Wpc into 2 Ohms). the rule is; an amp should yield twice as much power when impedance halves. for class A amp this is natural. class AB generally stuggle but there are good examples too.running123 said:havent met an amp yet i haven't overheated, and i have a small room...but i am a special case. Even overheated active speakers...
