Advice for new tv (big brand budget)
kitkat
162
Looking for a new 42" tv to replace my old (but much loved and enjoyed) 37" 720p Panasonic plasma, on a very tight budget, I do not require 3D, smart etc, just a good picture, I prefer plasma because of the black levels and fast motion but would consider LCD maybe. I don't mind if its 720p or full HD and the sound is not that important as I use my hi-fi for the tv sound. Any suggestions please,
i recently upgraded from a 37 inch panny to the 50gt50,and the difference is night and day,id suggest looking at the new st or gt 60 models if your happy to stay with plasma.
Think I heard that the new Panasonic GT range has loads of problems with faulty panels so best avoid unless someone tells me I am wrong about that.
Best thing to do is to buy from somewhere like John Lewis, but that is not possible with the ST and GT range though.
I believe it was the 2012 GT50 that had lots of problems, haven't seen any reports of issues with the 2013 GT60.
bigboss said:
I haven't seen many people owning the GT60 either, at least not on this forum.
I think it is quite hard to buy, most people bought from John Lewis last time with the GT50 or a Panasonic shop which they then regretted if faulty.
Can you fit a 51" in or are you limited to a 42 inch due to space?
http://www.whathifi.com/review/samsung-ps51f5500
this has a cracking review you the cost and is under your budget as well :bounce:
