hi i have the panasonic 55vt65 tv i am trying to calibrate my tv for the best picture quality how do you get into the advanced settings mine is greyed out need help? :cheers:
If I recall the advanced settings are used in the Pro picture setting. You should find a screen to enable ISF mode and that will give you access to Pro 1 and Pro 2 where you have Dynamic, Normal et al. From within that you should get access to the advanced settings. A professional calibration will get the most out of your TV.
