Hi all,
I am looking into buying an Accuphase amp and while browsing through their specs I am somehow confused about their power input/output ratio.
For example the specs on E-470 claims the following.
Rated Continuous Average Output Power (both channels operating simultaneously, 20 - 20,000 Hz) 260 W/ch 4-ohm load
Power Consumption 92 watts idle 420 watts in accordance with IEC 60065
Accordin to these numbers the amplfier will give an output power (260*2 = 520W ) higher than the consumed one (420W) which should not be feasible.
Does anyone know more about how Accuphase is rating their specs on this matter?
Thanks!
Thanks!
