Ok, lets put some facts to this thread.
Sound pressure level (or just level) is a measurement of the variations in sound pressure. It is a measurable fact, just like feet and inches but measured in db. (strictly speaking the deciBel is a comparative measure, a ratio if you prefer)
In hi-fi the first thing that you need to know is that it is a log scale, ie 10db is ten times, 20db is one hundred times, 30db, one thousand times.
The second thing you need to know is that for a hi-fi system to be increased in level by 3db, you need the speaker to produce twice the acoustic output, ie the amplifier needs to produce twice the power. For the level to be increased by 10db, you need 10 times the power etc, etc.
Loudness (percieved volume if you prefer) is a subjective measure of how loud something seems to us. It is different for everyone but if we take the average results from a large group of people we get the following.
Most people can hear, as a change in loudness, a difference of 1db in SPL, that though, is under controled conditions in a test. A discernable change in loudness in a hi-fi system, in a normal environment, playing music is more likely to be closer to 2db. A clearly noticeable, significant change of loudness is likely to be 3db or more.
Twice as loud is usually considered to be a 10db change in measured level, though some research suggests about 8db more realistic for many people. These are subjective evaluations remember, a degree of spread is to be expected.
Back to the OP. The change in nominal impedence is difficult to judge, you would need to see the curves and know how to interpret them, but from the figures above, a 2db drop in sensitivity might not be much in terms of percieved volume but is significant in power terms, ie to maintain the same headroom your amplifier would need to be approx one and half times as powerful as for the more sensitive speaker.
