Three? So that’s Left channel, Right channel, and errrm?I need to play music in two different big rooms and I thought I would need 3 speakers in each.
Maybe I am wrong
Apologies then,I just did a quick Google.They re £99/pair.
JBL Control 1 Pro WH - White Two-way Compact Installation Monitor - PairDefault Title
The JBL Control 1 Pro Pair combines high performance, compact design and rugged construction into a line of loudspeaker systems with unprecedented versatility.studiocare.com
Anyway, suggestions are welcomed.
Okay, thank you for your replies.
So maybe the best solution would be 4 speakers.
Can you suggest me something with a budget of £350 for speakers and amp?
I was thinking about ceiling speakers, but that would cost me lots for installation.
Bluetooth speakers, but I am not sure the signal would go through the glass partition.
So...I am a bit lost
I am attaching a 3d layout of the place
