5 X A-10 Monitor Audio???
Hello everyone,
I am upgrading my Kef 3005se speaker system and putting them into another room. I have been told many a times to get the Monitor audio Apex set because my room is only 3x3m and these would work well as the RX6 would be overkill for a room this size.
This has got me thinking how would 5x A-10 sound instead of the usual 4 and the A-40 centre?
Has anyone on this forum looked into this or should I just buy the A-40 as I was meant to be a centre speaker for this set up.
Hi magmax,
The Apex is an amazing piece of kit. Pair it up with the correct receiver and you can't go wrong. My room is similar sized to yours and it will be a treat to the ears.
You have to run the speakers in though. And oh...you must get the A40. Looks and sounds amazing!.
Get the Apex if your budget allows. You wont be disappointed
