I've been wondering if it's possible to give the DM5's a little extra dynamic range at high volume levels by filtering the sub bass below 40Hz. As the DM5's don't have any bass below 50Hz filtering everything below 40Hz shouldn't make any difference to the sound at normal listening levels but at high volume it would make life a little easier for them.
My Yamaha AVR doesn't have any functions which would allow me to try this so I was wondering if there's any sub filter that can be fitted between the Yamaha's pre-outs and the DM5's.
Can anyone recommend a product that can perform this task and is it likely to make enough difference to be worth the hassle?
