3d glasses not syncing with tv
rocketrazor
122
Hi guys,
ive got my second gt50 and thought today I'd watch a 3d film. Unfortunately I can't get the glasses to sync with the tv. I have two pairs of glasses and both worked fine on the old gt50 but they won't sync on the new one. I changed the battery just in case but all the lights come on but no sync. Is there anything else I need to do, can the glasses only sync to one tv?
cheers
In my experience (and I've been through a few TVs of late), getting glasses to sync with a new TV (even the same model) takes quite a few attempts. It should work eventually; just keep repeating the procedure. I remember standing there for a good 15 minutes trying to get glasses to sync with both of my replacement GT50s. It's not a manufacturer specific thing, either. Getting the TPS glasses to sync with a replacement TV took just as long.
Cheers strapped, ill try again tomorrow I was starting to get bored turning them on and off again and figured ten minutes was long enough
All sorted, the trick is to hold the button on the top of the glasses in the mode setting for 30 seconds 🙂
Samsung glasses synk in around one, two, three seconds.... from anywhere in the room even though they pamphlet says from a few inches..... strong signal eh ? :bounce:
ps/ Glad you got it sorted rocketrazor 🙂
which 3d glasses are you guys using been looking online panasonics seem much more expensive than other makes claiming compatibility,cheers .
