Dear Community
would any kind soul be able to advice me on whether the following are compatible with enough quality sounds for a large double ceiling (6x8m) room of up to 80 people aiming for 95 db mean sound level with contemporary electronic dance music without undue dammage to equipment (exept perhaps the odd human cochlea). does it matter which outputs i use on a 7.2 amp?
i have:
1 x sony str dn1050 AV receiver/ amp
7.2 Ch. 1155W A/V Receiver (165 W x 7 at 6 ohms, 1 kHz, THD 0.9%)
and 4x Wharfedale 2090 Installation Loudspeakers 200w Programme / 100w Continuous
SPECIFICATIONS Configuration 2-way Frequency Response (+/- 3dB) 50Hz - 20kHz Power (RMS) 200 Watts Impedance 8 Ohms Max SPL 119dB Woofer 8" Tweeter 25mm loaded titanium dome Rigging M6x8, M8x2, u-bracket Inputs Speaker Cable Weight 7.9kg Dimensions (H x W x D) 270mm x 445mm x 220mm
i also have 2 Ruark CL-10 speakers if need be
thank you for your wisdom!
i have:
