2.1 or 5.1 for surround sound?
I am looking to buy a home theatre (BluRay player, AV & speakers). I have a very limited budget of approx £800 to get all this. With the budget constraints in mind, would it be a better option to get a more expensive 2.1 speaker set which offers virtual surround sound than a lower range 5.1 setup?
professorhat
992
22
18,895
What is your main aim from the system - movies or music?
From my experience, only the upper end of the "soundbars" get anywhere close to providing a reasonable surround experience, and are still soundly beaten by many budget 5.1 systems. So if surround sound is the main requirement, nothing beats 5 speakers dotted physically around your room.
An all-in-one unit might be the best solution - are you just looking at a Blu-ray system or would you want to connect anything else?
Primarily this system will be for Sky HD and BluRay TV/movie playback. In a perfect world I'd also like to wirelessly playback hi-fi quality music from my iTunes library which lives on my MacBookPro.
fr0g
445
If it was me personally I'd pick up a good budget AV amp (Yamaha RXV-671), £300
Then a good budget BluRay player around £100.
And some good budget speakers around £400 (stereo)
Then I'd save up for sub, centre, surrounds.
But you can pick up something like the Boston Soundware package for £220 (Richer sounds) (5 star WHF review) which includes all speakers and sub.
Add a budget AV amp and BR player and you're set.
Lee H
336
Also, are you prepared to consider second hand goods? You can get some bargains on a well know auction site.
I would go for 5.1 though, but if possible, make sure it's something you can improve as time and funds allow. My first "proper" 5.1 involved some £100 Kef speakers and sub (from eBay) and a £350 AVR.
I've considered going for 2nd hand in order to get something decent. The only set back is that I do not know what kit is 'good' and what is 'bad'. There is a lot of choice out there, and you're never sure how well its been kept.
I have only been to Richer Sounds so far as I can atleast get some advice of what is good in my price range (although that advice can vary depending on personal experience of different sales staff).
Lee H
336
In terms of what is good or bad, that's what the people on here are for :) My first post was along the lines of, "I can get these for speakers for £100, should I?"
You're right though about how stuff has been kept and any vendor worth their salt will let you listen to the speakers first.
IMO, I'd only spend around £100 or less on a Bluray Player. You can get some bargains on last years models of AVRs too such as this from Richer Sounds. Add in some speakers and there's a bit spare for some cables to connect it all together.
All of this would be upgradeable in future should you decide to go down that route.
