1m HDMI Cables
About to order a 1m QED Qunex HDMI-P, any others for around £50 I should consider instead?
Where online did you get yours from?
Thank you for your opinion. However I have no problem spending 1.5% of the value of my AV set-up on a cable.
Back to the question: Any around the £50 I should look at? Anywhere in particular I should order from?
[quote user="Eddiewood"]
[/quote]
Spend it then. but it will do nothing. (Unless you happen to have a really long cable run, but that might require more than 50 notes). just make sure that the connectors are attached well and that the Ends are a good fit as some can be a poor fit in some kit. But you will not know that until it arrives.A cable that may fit your requirement is the Supra HDMI cable nice ends, certified solderers. and is not too cheap. and is HDMI 1.3.
