your experince can help............
(1)what is the definition for "LARGE" and "small" floorstanders........is it the size of speakers or the power it can handle or both............... (2) what is the best setting for "Dynamic range"...max/std/min.....(for yamaha amp) (3) what is the best setting for "bass"....main/both/swfr....(for yamaha amp)
[quote user="mandeep"](1)what is the definition for "LARGE" and "small" floorstanders........is it the size of speakers or the power it can handle or both...............
(3) what is the best setting for "bass"....main/both/swfr....(for yamaha amp)[/quote]
(1) Power handling. If you are using satelites, use "Small", if floorstanders, use "large"
(2) Standard
(3) Both
