- May 27, 2009
- 582
- 0
- 0
I hope someone kindly can help.
Set up with the auto option is generally OK and I guess that the equalizer tweaks each speaker to match the room. Using the GEO function and adjusting the frequencies manually is all guesswork. I dont really want to buy a sophisticated measuring device. Is it true that if the auto setup is used then not ony can you not adjust the frequencies but neither can you 'see' them for a bench mark. Using the PEQ only allows you to alter the relative volumes and crossover frequencies but not any individual equalizer values.
Auto gives all my speakers LARGE and a crossover at 40Hz but I change these all to SMALL except the front floorstanders and the crossover to 60-80Hz.
Hope someone can help.
Aint life loads-a-fun ?!
