Xbox 360 as a music player...
Would it be acceptable to use my Xbox 360 to play CD's and as an iPod dock through the gold RCA outputs into my hifi setup or would it be a far better idea to purchase an ipod dock and seperate CD player? I am talking in terms of audio quality... Many thanks
JoelSim
767
It all depends on what your set-up is and what sort of sound quality you are looking for, If you have a separates system then you should maybe consider a new CD player.
Depends what you define as being "acceptable". Even a cheap (i.e. £150 upwards) CD player will give you better sound than the 360, and that's before you consider what a noisy beast it is with the disc transport and the fan competing to outdo each other for noise levels. Personally, I reserve my Xbox for what it's best at, i.e. games.
well the set up i plan to get would be a pair of BR2's with a Rotel RA-04 amp. Ignoring the thunderous sound of the 360's performance, would it be worth getting a cheap CD player of the type you specified? By worth, i mean worth saving up when i earn only about £40 a week... Thanks
Well, in that case, your amp and speaker combo actually deserve a CD player of at least £200 - £250. I'd be thinking Marantz CD6002, which I believe can be had for £200 new. In your position, I would use the 360 for the time being and save the pennies until you can buy a decent CD player. Even if it takes a while to save the cash, it'll be worth it in the long run. You'll have an excellent system.
