- Aug 10, 2019
- 2,556
- 5
- 0
Hi everyone,
Im afraid this is basically another one of those comparison threads, yes i do know a lot of it is down to personal opinion but all are welcome.
I have a marantz PM6003 combo with B&W 685s. The system sounds very good with 'simple' music with just a single voice and one or two instruments/beats/layers (however you describe it) John Mayer, Michael Buble for example. Although i have a lot of that type of music in my collection it is probably a 35/65 split with complex rock, Hip hop RnB music. I find although the bass is very good the separation between layers of tracks is not great, for example heavy nickelback/muse tracks. With vocals sometimes losing their presence and separate instruments blurring into one.
My question is would a Rotel pre/power combo improve the shortfalls i have mentioned above? Im aware now(wasnt at time of purchase of marantz equipment) of rotels great synergy with B&W.Im sure the speakers are the best part of the system so definitely want to keep them. If a change to rotel wont correct the above then I shall stick with what i have.
Id be looking along the lines of RA-02/03/04 with RB-03/06 although suggestions of others are very welcome, obviously id consider used.
Importantly I really dont want to lose the voice and instrument clarity given by the marantz on less complex tracks by changing to rotel.
Finally I dont really have the opportunity to listen to equipment alot but i like good voice clarity, strong bass for dance,hip hop, rock and just for instruments to sound as 'in the room' as possible. room is 5mx5m.
Hopefully that helps to give you an idea of my situation.
oh and budget would be whatever i sell the marantz amp/cd for +£100.Although I may keep the cd player.
