Windows Speaker Enhancements
BEDROCK
59
Which options would you use for a laptop with a pair of M-Audio Studiophile AV 40 speakers?
Speakers are connected via the 3.5 headphone socket to the phono L+R line in socket.
I have TRS inputs on these speakers, will there be any benefit in connecting via that route instead?
The bit depth format is set at the maximum 24 bit 192000 hz (Studio Quality) setting for best output.
Bass Management
-Office
-Home Theatre
Virtual Surround
Room Correction
Loudness Equalization
-Short
-Long
It won't matter whether you use the phono inputs or the jacks, the sound quality will be the same. And to be honest I'd turn off all the software EQ settings.
If you want to improve the sound quality your best bet is to buy a separate DAC. The ones built into computers usually sound pretty naff. If you only intend to use the DAC with your computer, you can buy a USB one.
Fiio E10 is very highly regarded, or if you have more to spend, the one which seems to be wowing crowds at the moment is the Dragonfly DAC.
For listening to MP3 music and watching videos, is it advised to use the maximum 24 bit 192000 hz (Studio Quality) setting?
No it won't make any difference unless you're listening to lossless hi-res music that you've downloaded at 192/24.
So is 16 bit, 44100 Hz (CD Quality) the best I should go for or can I use another setting?
