Which Speakers For The Price Shall I Go For?
Hitherto
Hi Guys Im In Bit Of A War Of Which Speakers To Buy As I Want To Bid....Either Mordaunt Short 902i Or Eltax Monitor III Or Tangent Clarity 4....All Your Help Will be Appreciated
The obvious answer is, whichever ones you like the sound of the best.
Seeing as you say bid, I'm going to assume that you will be buying them blind, so to speak. In that case, it might be easier for people to give an informed opinion if you let the forum know what equipment you plan to partner it with, size of the room, the type(s) of music you listen to and what kind of sound you like (neutral, open, revealing, accurate; coloured, warm and cuddly, etc.).
Thanks for the reply...im still new to forums so probably havnt made myself to clear..i will be using speakers as mains and will be in my living room..music wise im into all sorts but mainly electronic to alternative so need something versatile
