- Aug 10, 2019
- 2,556
- 5
- 0
I have Yamaha 863AVR, and B&W 703 (front) / 6xx series 5.1 speaker set. As this Yamaha's speaker connections are very badly located at its back and difficult to connect the wires in a good way, I am looking for a banana jack set. Which one should I use. If you consider I need 28 of them (14 pairs), I need the ones good performance but low cost.
