When design has gone wrong
RoA
1,308
1,020
13,070
Arcam. Their old FJM range looked great, high end with their green displays and 'precision instrument' look. Distinct. It went downhill with the SA range of which I have the SA20. In fairness, it is rock solidly built but I do not agree with their design 'improvement'. The colour is somewhere between black and a bronze/grey ... . It has, imho further deteriorated with the latest range and the yellow go faster stripes, the overhanging case on the rear which makes it more difficult to access sockets from above and a display which looks like vaseline was smeared over it. Terrible design department.
All subjective of course and you may well disagree.
Technics SL turntable. I have the 100C. Great unit but ... the decision that you have to lower the tonearm first to place it in the holding cradle (what is that thing called?) AND THEN RAISE IT AGAIN BEFORE CUEING ... is imho absolutely stupid. My partner nearly took the stylus off when she forgot to raise it, moved it across and bent the needle because it bumped into the platter. Luckily it was the cheap conical one rather then the new Microline. I managed to carefully bend it back, still ... .
Quite a few turntables work in that manner.......
Reactions: RoA
In the turntable hey day lifting the arm up before moving over the platter was normal, (You didn't think about it as it was what everybody did, so there were never any problems.
Turntables are pretty much same today as they were then, so hardly surprising that they operate the same.
As to Quality and looks, then for me the Michell Gyro deck still reigns supreme.
Bill
...the overhanging case on the rear which makes it more difficult to access sockets from above
Perhaps because I've never accessed sockets from above, that wouldn't bother me.
In fact I made an improvised cover for my old Cyrus to keep dust off the connections.
It seems they've deliberately blurred what could have been a clear display.
That's just silly.
Bill
My memory may be fading but I thought my (late) P3 didn't need lowering after playing. Perhaps I am wrong.
There’s definitely a considerable number of Facebook groups devoted to vintage gear, where the overriding impression is that folks would be happy if modern kit had more buttons and knobs.
I suspect cost of manufacturing and reliability might both suffer, but the traditional brands like Luxman, Quad and Accuphase have a definite following. I’m less taken with the ‘steampunk’ designs that have recently appeared from new companies, but they are at least more interesting than a screen plus two rotaries!
I agree that the Technics cueing is its worst feature. Otherwise it’s brilliant.
Reactions: RoA
I’ll add another one. Roksan’s latest Caspian. I actually like the design but the source selection display is way too small, no way anyone can see this from a seating distance. You get to know what it is after a while but their previous top integrated, the Blak, had a lovely large read out. Others are guilty of this too.
Reactions: nopiano
And one more, because it’s Saturday 😀; AudioTexhnica’s cartridge ‘protectors’ on their basic 95 line. You’ll have a greater chance damaging your stylus if using it.
I miss the old flip-down guards that Shure used to fit, but the downside is the greater mass and chance of resonance.
Manufacturers might be less bothered if they garner more sales from pullover wearers! 🤣
Reactions: RoA and Gray
When it comes to design, I go in two opposite streams.
Amplifiers I like to see clean design, a minimalist approach but also functional. None of this layers of weird noir Avant Garde nonsense.
Streamer DACs have evolved, these remind me of mobile phones on steroids. I like the big touch screen. I think it's important they engage with the user to compensate for the lack of physical medium, like the artwork on your album.
The overhanging rear lip on the rear of the A25 was a real non-issue in my opinion. How often do you actually need to reach the sockets after you've done the initial setup?
I wired mine up with the rear panel facing me, rotated the unit and forgot about it.
I agree. Most people wire things up once and you're done. Only those who mess about and change things all the time will find it a chore. If the cables are long enough, it won't be an issue anyway if it's situated on top of a rack - if it's within the shelf of a rack, that's trickier.
Reactions: RTHerringbone
My rack faces a corner and I have a number of amplifiers I rotate. It's rather difficult without it having overhanging top panels, impossible if they had. I just can't see the purpose of it other than (partially) hiding the plugs.
1st world issue but form over function.
Quad 3 integrated amplifier. Nice vintage basic design but the tiny letter box display together with unmarked selector knobs are form over function. Not too clever.
