I'm building a new home and it will have a fair amount of smart home stuff that will be voice controlled, so I plan to have one amazon echo dot on each room speaking through the ceiling speakers.
I don't need (although it would be nice) to stream music across zones, so I was planning to have one amp in the living room and another in the kitchen, both connected to a pair of stereo speakers.
On the living room the amp will be on a shelf, so no peoblem. But on the kitchen I don't have a good spot for it and I planned on having it inside the ceiling and never ever touch it, paired via Bluetooth with the echo device.
But if I do that, how will I be able to control the volume? Are bt amps capable of changing the volume based on commands from the source or will it have to have the amp at high volume all the time and make the source emit at a lower volume to fake it? Would it be better to mount a volume knot in the wall? Perhaps a bt amp with a remote?
Also, I don't want to spend a ton of money, perhaps 350$ on a pair of speakers and the Bluetooth amp. What setup (amp/speakers) would you recommend?
Thank you for your wisdom.
 Facebook
Facebook Instagram
Instagram
