what stereo amp to use with pioneer n50 a network player
Instead the N50+amp idea you could consider Bluesound Powernode2 and NAD D7050(no i-net radio) if you are fine with their inputs.They would combine streaming features and amp.
Otherwise i think the Peachtree decco2 is a very nice and versatile match.You could also consider the Pioneer NP01 as a streamer which would be less expensive than the N50 and does not sound worse.
For the Pioneer, the whf suggestion is great - Arcam A19. Also, seriously consider a speaker upgrade - Focal Aria 906 are perfect with the Arcam.
Alternatively, check Naim Unitiqute 2 + Focal Aria 906. The naim is very robust and sounds amazing.
