What PC Speakers match Shure headphone quality?
I'm currently on my third pair of Shure heaphones, I cannot listen to music through any others sine my original pair. I'm currently using SE210 because the iPhone doesn't drive the higher ones very well, so I saved myself the money. However, now whenever I listen to my music in my room I really miss the depth of sound. I have an early 08 MacBook and I've tried many minature speakers, but nothing is good enough. I'm looking to spend ~£200 on a set up to get a good range of sound. I mainly listen to dance and electronic so they need to have good bass, as well as be able to handle highs and mids. Any suggestions as to what I should be looking for/models I should look at?
For that price it's hard to see past Audioengine A5s, if you can fit them on your desk (they're quite chunky). Alternatively, the A2s may suffice, and are more desk friendly.
Ta. They are a bit chunky, but I'm sure I can find somewhere for them...
