Hi, here's my situation:
I purchased a 650A from Richer Sounds but was lent a demo model while they get a silver one in stock, so i'm still able to switch it for something else. Like mathewpiano was saying, i like the incredible detail but find it a bit bright sometimes.
I'm thinking of trying the NAD 326 but am worried that although it'll be warmer it might be a step down in terms of quality. The What Hi Fi review said it would be found out if partnered with hi end speakers, are the CM1s high end enough?
I could get a 'graded' 740A for just a bit more than the 650A but its only listed on their website store so it might be a bit complicated. Unfortunately i'm limited to Richer Sounds' stock unless i sell the new 650A on ebay and used the cash raised to get something some where else.
The manager at Richer Sounds said the DAC magic may be causing some of the brightness and suggested changing interconnects (apparently Chords are quite bright) to some heavier copper ones but i'm not sure how much they can change the sound.
Please let me know if you have any views/ideas.
