What amp and speakers please help
scott608
10
I bought a Project Debut SE3 turn table with a:
Pre amp: CAMBRIDGE AUDIOAZUR 551P. I now need to get an amp and speakers to suit. I have a budget of £1000 maybe push to £1500.
The speakers will have to be hung from a wall bracket so speaker stands are a no I'm afraid.
Any support would be much appreciated so far I'm thinking Arcam fmj19 with some Bowers and Wilkins 685 S2's.
Scott
If you have to wall mount, check out Neat Iotas. Then spend as much as you can on the amp, a Creek 50a would be a good choice.
thanks for your advise with these I had never even heard of the Neat lotas but they do seem to be getting very good reviews, I will need to demo them with the creek amp you suggested.
thanks again.
