What 2.1 systems are available?
kusum65
68
About time i joined the home cinema revolution so im on the look out for a 2.1 system, possibly an all in one box.
Speakers and sub are taken care of just the electonics im after and i dont want to spend any more than £500.
The cambridge sonata system appeals , the dvd player has been reduced but the reciever is still a little expensive.
Any suggestions please.
Kusum65,
Your 2.1 blu-ray system choices are:
1. LG HB45E - £400 (4 ****)
2. Panasonic SC-BT222 - £300 (4 ****)
3. Samsung HT-C6200 - £450 ( 5 ****)
The reviews for these can be found in the latest issue of the magazine.
Ronald
Thanks Ronald. These sytems have speakers and subs . I would rather use my existing Hi Fi. My Rotel stereo amp has a sub output i dont use as i link the sub with Hi level connections but i wont get real cinema effects using this i believe so im looking for electronics minus the speakers please.
The Arcam solo 2.1 movie unit would be perfect but i dont want to spend that money. Im also not to bothered about Blue Ray just yet.
Sony str-dh810 + Sony 370 Blu ray player which will take care of your DVD's too. If you ever want to progress to 5.1 then you are future proofed
£500 is a pretty healthy amount, but getting a 2.1 receiver will mean if you want to upgrade in the future you'll have to change equipment. I would def get a 5.1 receiver which will be fine for now but allow the expansion to 3.1 or 5.1.
If you can leave yourself £100 or so get a centre speaker (3.1) which will make a big difference
Thanks for the suggestions guys. I have to say though im not interested in 5.1 due to room constraints. I just want the sub working with the soundtrack properly.
The cambridge sonata dvd and receiver would be perfect for me having dedicated sub input/outputs but although the dvd is currently at a good price ( £79) the receiver is £320.
They had a model minus DAB radio at £200 but that seems to have gone. Im not paying an extra £100 for DAB radio. Been there done that wont do it again.
