I've just bought a new Denon AVR-X2200W AV Receiver and I'm having a few issues with the subwoofer setup. I changed from an Onkyo 626 receiver and everything was working perfectly, but now I have to have the levels for the sub up to +10dB to get decent Bass with everything else down a LOT lower.
I have the following hardware:
Q Acoustics 3050 Fronts, 3090 Centre and 3010 Rears. I have a BK Electronics XXLS400 sub.
I used a SPL to measure the levels from the sweet spot so that all of the speakers were at 75dB with the results below:
Front L -7.0
Centre -8.5
Front R -6.5
Rear R -3.5
Rear L -3.5
Sub +10!!
Settings on the receiver are as follows: Crossover is set to 80 Hz. Distances are all set correctly. All speakers are set to 'Small'. Subwoofer Mode is LFE. LPF for LFE is 80 Hz.
Settings on the subwoofer are as follows: High Level not used. Single RCA input. Gain set to 12 O'Clock (half). Filter set to Out LFE. Frequency set to 12'Oclock (not used though as the Receiver does this). Phase set to 0.
So it sounds good now, but I'm worried that something is wrong as the dB level for the sub is so high, but on my older Onkyo it was much lower, in fact it was the same as the other speakers. The SPL says that everything is at 75dB during testing but I'm worried something is up with my settings!
Any suggestions?
Front L -7.0
Centre -8.5
Front R -6.5
Rear R -3.5
Rear L -3.5
Sub +10!!
Any suggestions?
