WASAPI not working...any advice?
acalex
73
Hi guys,
I just received my first set today and since I am playing only from pc I tried to do somthing to improve the SQ vua software. I found an article of PJPRO on WASAPI but it doesn't work. I am using an Arcam rDAC and I installed foobar2000. I go to preferences and I chose output...then I select WASAPI: speaker Arcam rDAC
Format 16bit untouched and buffer 1000ms...I press play and get this message:
Unrecoverable playback error: Unsupported stream format: 44100 Hz / 16-bit / 2 channels
Why is that? Thanks
Hi there,
If you change the output data format to 24-bit that should work. I had the same problem when using WASAPI on Foobar, I don't quite know how but Foobar has imported my Amazon mp3's as 24-bit. I use the ASIO plug-in with ASIO4ALL download and you then don't need to set or change the output data format.
Hope this helps.
bezza79 said:
Hi there,
Hope this helps.
Indeed it works but I have to change the buffer from 1000ms down to 100ms otherwsie I keep getting disturbs...
Do you really think that using Widows 7 64bit and an Arcam rDAC connected trough USB there is a sensible improvement by using WASAPI? Because I really can't spot an huge difference...when I use foobar with WASAPI or VLC to play my MP3...
