Wall Bracket for a Pioneer 5090
hammill
212
Hi All,
I need a bracket for my 5090 and have been looking at the Premier Mount AM250.
Does anyone have any experience with this combo or other recommendations for the 5090?
I am curious about this too. I have a 5090 (reserved) and previously bought a VESA compliant tilting wall bracket (32-63", 70kg max) but I have been totally stumped with finding out if the 5090 is simply VESA compliant.......
Anyone?
Personally I do not have the LX-5090, but you could also consider the 1st Party Pioneer wall brackets.
PDK-WT02 Angled Wall Bracket
or
PDK-WM02 Wall Bracket
More details can be found here and can be bought here or here
Didn't your TV come supplied with the wall bracket? My Pioneer came supplied with the bracket so I'm assuming that it is from Pioneer. Try going back to your dealer and ask for it.
I think any wall bracket would do unless you want something fancy that can tilt/swivel by 180 degrees, etc.
The 5090 does not come with a bracket. I do want something fancy
