I am hoping that some here could please help out a newbie here. I’ve recently eBay purchased some vintage gear to replicate what my brother used to have in the late 90s - Denon PMA 100M amplifier, Technics CD and Turntable. I also got some book shelf speakers ( Mission DM7 speakers) only very recently, which I hooked up to the amp using 14 gauge cables. All equipment advertised as working from good rated sellers.
The problem is the sound I got was very quiet, even with the increased volume - no bass detected - just the faint top ranges but barely audible. I checked the wiring and connections to see if I connected +/- wrongly, which I’m certain I have not. Even swapped different CD players on hand and then the turntable. I can say that I suspect either or a combination of amp, wrong gauge wiring(?) or speakers. The Mission DM7 speakers are at 8ohms at Frequency response 70Hz to 20kHz, recommending an amp at 50w. I’ve been told by Youtube channels that a powerful amp can run speakers at a lower wattage so I thought I the amp would be ok with these speakers. As for the connection from amp to speakers, I think would be A+B for 8ohm configuration (one coloured wire into the top port (Row A) and the other into a bottom port(Row B)) - I hope I have read that diagram correctly on the back. I’ve tried all wires connected to corresponding lower row B ports but the same sound came out.
Other than that swapping out both speakers are creating the same small sound regardless and I’m not ruling out faults in the amp or speakers at this point.
Thank you, forum members for any pointers or advice. D
