- Feb 13, 2013
- 3
- 0
- 0
The bulk of my Budget System was set up in 1988 following visits to the first few Bristol Hi-Fi Shows . I have a Sony 500ES Tuner , Philips CD840 CD , Sony TA FE370 Amp and Diamond 9.1`s on wall mounted Target stands . The last two are only 8 years old . I have a second Vintage system from 1988 in a second room , Pioneer Receiver SX434 , Philips CD 160 and Heybrook Point Fives . These Heybrooks formed part of my original System with a Sansui AU G30X which I still have , although it has a fault .
So much for the history lesson but the Bristol Show has prompted me to think of changing my Amp . I mainly listen to Classic FM and occasionally a CD . My listening is done at low volume levels otherwise my Wife complains . I have listed the following Amps and would be grateful for any guidance on reducing the list a bit .
Onkyo A9030 and Onkyo A9050
Pioneer A30
Marantz PM6004
Denon PMA 520 and Denon 720
Yamaha A500 .
I would like to keep the Diamond 9.1`s , but could swap them for the Heybrooks if needed .
Any suggestions would be gratefully received .
Roger
Pioneer A30
Marantz PM6004
Yamaha A500 .
Roger
