Upgrade Amp
da_grudge
76
Hello all. My system is composed by MA RS6 , Arcam AVR 350, Oppo 981 and DacMagic 2.
I would like to upgrade my amp, using this one for movies and buy a dedicated stereo amp.
I listen a lot to Led Zeppelin, Pink Floyd, a lot of Jazz and Classical Music. I would like to get a little more detailed and transparent sound than I have now.
I really can´t spend much money on the amp, so I thought to buy something second hand on ebay.
What do you recommend for making good match with my speakers and the dacmagic?
My budget would go to 200 pounds, but of course that sometimes you find expensive amps for really cheap in ebay, that´s what I am looking.
Thank you
there are plenty good vintage amps on ebay ,,, here are a few .... do tour research, ask questions and take your time choosing! .... I am sure that you will get loads of suggestions ... here are a few that are currently listed on ebay: ... good luck!
pioneer A400 should cost between £80-£120
Pioneer SA-1000 ... old but good ... buy it now for £169.99 ... ebay item 250498962178
sansui AU-D9 ... £159.99 buy it now ... ebay item 250502609576
SANSUI AU 417 ... £250 on buy it now ... ebay item 170387617869
technics vc-4 class AA SU-VX500 ,,, buy it now £99.99 ... ebay item 250504111537
thanks for the list. I also would like some sugestions on which would do a better pair with my MA RS6 and DAC MAGIC2.
Tx
If you can find one then I'd say go for a NAD C352 integrated or an Arcam Alpha 9 or 10 integrated.
Having owned the same speakers and listening so similar music I'd say they'd all do a very good job.
Get an older Cyrus amp. Many of the later ones have an AV bypass option which sets volume automatically when using AV
