TV from projector
rendu
192
Hello, how can you watch tv with a projector. Do you need a TDT TV receptor or, do you plug to the normal tv but, in this case how can you do so that the tv only displays in the projector. I have optoma hd 65 and a HD samsung TV 32". Thanks.
You need an external tuner of some sort, either a Sky box or Freeview/sat tuner to connect to the projector, I doubt you can get a feed from your existing TV to the projector.
ok, thanks that is a bit dissapointing. We do not have Skibox or those options in Spain. I will have to find out what are the options here.
There's a TV tuner available for the PS3 which presumably would allow you to feed the projector with the tuners feed?
Not sure if UK spec tuner would work in Spain? There may be an EU version available.
Cheers,
Cofnchtr.
If that possibility exist then, it would definetly be a very good option. I will investigate a bit further. Thanks.
