tv cabinets help needed
timwileman
296
you could try some of the sites with links on this site under dealers, or try some furnature makers sites or in my case i looked on the JL website and saw a nice TV stand at half price, only problem now is that other half likes it so much she wants the matching table etc.....grrrrr!
[quote user="bobbys"]any one know of any good sites cant seem to find any other than stand and deliver[/quote]
If you only want the stand, Icon at Amazon, £50.
http://tinyurl.com/6q2jte
I like the look of the Atacama Europe Ref 8, however, the weight limit for each shelf is 25kg and the TV I want to put on it is 26kg, I would rather not attach my panel to the wall. Are there any suggestions for a rack which will manage the weight and look similar to the Atacama.
Dave_
1,228
635
20,070
boltman:I like the look of the Atacama Europe Ref 8, however, the weight limit for each shelf is 25kg and the TV I want to put on it is 26kg, I would rather not attach my panel to the wall. Are there any suggestions for a rack which will manage the weight and look similar to the Atacama.
if you like that one go for it, i wouldn't worry about being 1kg over the limit,the limits on stuff like this is usually on the conservative side of things,
