Hi all - looking for some advice on a tv distribution setup.
Our TV arial enters the front room. Now we have never had the tv in the corner were the lead enters and have used an extension cable to reach the appropriate point. Now this has always needed a booster for my old bt vision box to work ie
Main arial lead > booster (13dB Gain <3db noise) > 10m extention > Vision box.
Now we are in the process of doing the 'rooms' so I have set up multiple tv plates (she likes to move the furniture alot!) Now all these cables run into the cupboard under the stairs some 8mtr from the corner were the main arial enters and I have run an extension from the main arial to the cupboard under the stairs also...with me so far!
What is likely to be the best setup for boosters and or splitters ie
Main arial lead > booster (13dB Gain <3db noise) > 10m extention > 8 way splitter > 10m extention (average) to each point > wall plate.
or
Main arial lead > Coupler > 10m extention > 8 way booster (8dB Gain - per port - <4db noise) > 10m extention (average) to each point > wall plate.
However as the original set up did not get a good signal using the bt box after the unboosted 10m extension would the above 'coupler' version not feed enough juice to thee 8 way booster and would I be looking at something that's a mix of the two using two boosters ie: Main arial lead > booster (13dB Gain <3db noise) > 10m extention > 8 way booster (8dB Gain - per port - <4db noise) > 10m extention (average) to each point > wall plate. CheersSteve
or
