Only noticed this when the other day when I switched the amp to the TT input whilst the volume was at 12 o'clock and my ear was only about 6 inches from the speaker. Quite an audible hum, although at normal listening levels (9-10 o'clock) and position (at least 2 metres away) it is barely noticeable.
Playing with the ground connection wire and the pre-amp ground terminal changes the loudness of the hum, but at no point can I eliminate it altogether.
Questions therefore are...
1. Is this level of hum to be expected with the Debut? - I mean, whatever the accolades it has, it's still a budget TT at the end of the day...???
2. Can I try connecting the TT's earth wire to ANY ground point (eg the TT ground on the 876), or does it have to connect to the pre-amp it is attached to? I'm wondering if the 640p grounding terminal is a bit suspect, and just want to confirm or eliminate this theory...
thanks
thanks
