Tuner recommendations
d_a_n1979
134
Can someone please recommend me a tuner for my system? I'd REALLY like it to be in silver but may consider black if pushed. It doesnt have to be DAB as I've got the Virgin V+ box plugged in to the amp for digital radio so I'm after a good tuner that has GOOD FM! 2nd hand is ideal and before you say it I know about the Denon TU206 MK II. It's just they always seem to be in black [🙁] Cheers
Just seen this FMJ T31, but unsure of your budget.
Yeah... Budget...
As little as possible TBH
Although I have found a few decent Arcam examples on eBay (the Alpha range) so am keeping my eyes on them
d_a_n1979:Yeah... Budget... As little as possible TBH Although I have found a few decent Arcam examples on eBay (the Alpha range) so am keeping my eyes on them
Okay, try this...
If it's half as good as my old Marantz it'll be well worth the "Buy it Now" price of £84.00...
plastic penguin:
Okay, try this...
Oohh...
That's pretty
Cheers PP
d_a_n1979:plastic penguin:
Okay, try this...
Oohh...
That's pretty
Cheers PP
No probs
Honestly, dan, if that tuner comes close to mine sound quality-wise, it'll be a bargain. I've tested my OAP against Pure Digital 702, Sony hybrid, very old Quad and Arcam DT91, and only the latter bettered it with overall sonic ability.
