A while back I mentioned that many reviews of AV receivers get so bogged down in their lengthy descriptions of their growing list of elaborate feature set, that the actual description of the SOUND is either terse or non-existent. As a prospective buyer putting a shortlist together, knowing their approximate tonal balance (for the purpose of speaker matching) would have been helpful.
So I'm going to put my brief observations of my Anthem here, but all you Denon, Marantz, Yamaha, Onkyo, Arcam owners out there, forget the specs for a moment, what do they SOUND like?
ANTHEM MRX 710
It's worth noting that I've come from a Pioneer AV receiver and my Ruark speakers are neutral to forward, bass light (for floorstanders) and a potentially excitable treble if put with a forward-sounding amp.
Overall the Anthem has an effortless mercury-like sound. Compared with the Pioneer VSX-2021 I owned before, it's significantly sweeter for 2-channel music. Its treble retains good snap and timing but never grates. Drums are exciting but strings are just right: retaining a certain amount of bite at the leading edge but silk-smooth too. The Pioneer could sound a little 'grainy' with strings at times.
One thing that's notably different to the Pioneer is the way it develops the soundstage, both in 2-channel and surround. The Anthem seems to tie together each speaker more effectively, so you don't really notice sounds coming from one speaker or another, but a large wall of sound is spread before you (&behind you with multi-channel). This has a strange effect on your perception. Of course, it's more like how sound works in real life, so its very fluid and natural and managed to sew together my small Apex rear speakers with my Talisman floostanders better than the Pioneer did. But I must say, in some situations the Pioneer had a little more sparkle and excitement. Because it actually sounded more like the sounds came from the speaker with the Pioneer, steering effects were a little more striking.
Another key difference with the Anthem is its handling of bass which is far superior to the Pioneer, which was its principal Achilles heel. It just didn't have the current to keep the bass in check, so often with bass heavy music I'd listen in 2.1 mode and employ the subwoofer. The Anthem, with its superior current delivery and ARC room correction just delivers bass exactly how I like it. Double-bass jazz solos are awesome now. Before they were all a bit one-note with the Pioneer.
So in summary, the Anthem has a sweet crisp treble, slightly rolled off compared to the Pioneer. Tonally, to my ears, it's spot-on and genuinely neutral I would say. Musical instruments sound 3-D, rounded, natural and real. It doesn't sound like hifi. So for music I honestly couldn't fault one aspect of the Anthem. I have a system that's as musically satisying as I can imagine for 2-channel, and it's an AV receiver! Movies are just as satisfying as the Pioneer, but it is different. The Pioneer could sound more exciting at low volumes, but could become harsh at mid volumes so you'd want to turn it down at times. The Anthem sounds more effortless and you just want to turn it up, but this could obviously be very speaker-dependent.
If you were purely after an AV receiver for movies, then I'd actually save a huge wad of money and go for the Pioneer. Its treble that could be a problem for music is exciting and addictive with movies. But I want a one-box all rounder with a preference for music and 2-channel sources. And it's there that the Anthem kills the Pioneer. With movies, the Pioneer had a slight edge in certain situations, but with music, the Anthem is in a different league all together. So as a one-box music and movies solution, I am a very happy customer: no buyer's remorse here.
It's always tricky describing sound, but I've had a go. Now, please at your own impressions of your AVR's sound, particularly its tonal balance if you can.
ANTHEM MRX 710
