To WattGate Or Not To
landzw
281
Hi i'm looking to replace all of my power cable , i currently have Copper-line Alpha and i was wondering if its worth spending the extra £15 for a wattgate ?
fayeanddavid
191
landzw:Hi i'm looking to replace all of my power cable , i currently have Copper-line Alpha and i was wondering if its worth spending the extra £15 for a wattgate ?
landzw
there is a similar thread discussion on the Home Cinema forum which I have started, as I'm about to take the leap of faithand do the same thing.
Thread starts with "I am a believer............"
Take a look
landzw
281
Yes i had noticed that , i wish i could afford the powerchords but i can't as one of my lengths needed is 3m and the other 2 are 0.5 & 1m
So since i had used a copper-line alpha before i was wondering if i should add as an added option a wattgate but i just can't seem to find any good reviews on the web .
There is a few mentions on other forums and some say its a con and some say they are great and when you look around wattgates are on most high end power cables but would it make a difference on a budget?
Even with the powerchords they don't come with wattgates and still the cable has cracking results
I'm on the line of thinking no one would have done a comparison with the same cable , one with and one without a wattgate , Maybe its something What HiFi could do in the future
True Blue
185
The Wattgate is a more secure connection, not sure whether or not you will gain significantly in audio terms therefore IMO you would be better saving and getting a better power cord, as you say the Chord Powerchord does not use one and I get cracking results from them.
Pistol Pete1
248
I get great results from the powerchords too...(hi again, True Blue, how r u? lol)
Look at hifix.co.uk for bargain powerchord prices on 1 metre and 1.5 metres.....
True Blue
185
Good thanks Pete. Saw those, only just bought some RA stuff (******) no funds left, cracking deal though
Pistol Pete1
248
Tell me about it!!!!
I have 4 Powerchord's now.......using them on receiver, CDP, blu ray and dvd recorder!!
They improve all the above machines, dramatically, in my opinion.
Just added the QED Signature sub cable and QED Reference aerials.....again, a good improvement in sound/visuals....
Just about done with upgrading now, though....will just have to sit down and enjoy them all now.
True Blue
185
Pistol Pete1:
Blasphemy!
Pistol Pete1
248
(Laughing).....ok, might be tempted, but not for a while...
All cables have been upgraded......no more to do...
True Blue
185
Back onto kit then LOL never ending circle :)
My next upgrades will be either
Small
1. New Chord Active HDMI
2. New optical lead
3. Final powerlead for my BRP
or
Big
1. New AV reciever Denon 2310
2. New Power amp Nap 200
3. New BRP
Hopefully at least one smallone big this year
Apologies to the OP going a bit off topic :)
wireman
17
landzw:I'm on the line of thinking no one would have done a comparison with the same cable , one with and one without a wattgate , Maybe its something What HiFi could do in the future
There is a guy called Howard Popeck - well known throughout the hi-fi trade - who has run a variety of retail hi-fi outlets over many years. He used to (and maybe still does) make his own range of mains cables called Cassiel. Apart from the very lowest cost one, all the others were to my recollection exactly the same cable - only the wattgate plug on the equipment end changed, from a basic 320 Wattgate through a variety of different contact materials, to some fancy Rhodium plated version by (I think) Furutech. The difference in performance of each Wattgate plug type (in his and his customers' estimation) was significant, and the price of each cable reflected this. Howard is still out there retailing Hi-Fi - whether his cables are I don't know, but he used to be open to home trialling the different variants so you could prove it for yourself.
clearer_audio
landzw:
Hi landzw
The Wattgate does provide improved performance with the Copper-line Alpha Power Cable in comparison to the Standard IEC. Current hungry components like amplifiers tend to benefit the most, although it is very common for customers to report significant improvements on CD players, DACs, pre-amps etc.
If you are considering the cable then you could try both the Standard IEC and Wattgate 320i IEC; you could also test against any other cables you might be considering. We offer a 60 Day Money Back Guarantee so you could return any cable(s) for a refund.
I hope this helps.
Best wishes,
Darren
