Tidy cables
How do you keep cables tidy,
My HC system is on a stand just off the wall as i presume most are, Speaker cables/Mains cables no problem as they are easy to tie and bend, However the hdmi are so stiff they wont bend and also come out of amp etc so far before you can bend around safely,so please how do you tidy your hdmi up
Maybe a market opportuity for someone to come out with 45 and 90 degree "up" and "down" HDMI plugs on their cables?
Hi
If a cable is not flexible then this is usually due to the construction and hardness of the outer jacket. Usually it is acceptable to gently warm a cable with a hair dryer to aid installation where additional flexibility is required. However it is always advisable to contact the manufacturer first to make sure this is ok (e.g., you cannot do this with some of our cables).
Hope this helps.
Kind regards,
Darren
