I have the Q Acoustics Concept 20s, with Marantz Pm6005
My question would be, should I Bi-wire the speakers and the amp. How is it done? The Marantz is capable of driving two pairs of speakers (I think) should i route a seperate speaker cable to all four slots, of the Speakers, and instead of two pair of speakers, I connect them both to one pair. Is that possible?
Thank You
AntAxon
47
Thank You
The Marantz owners manual is on the internet.
http://www.marantz.co.uk/DocumentMaster/master/PM6005N_ENG_CD-ROM_UG_v00.pdf
Look at page 17
From what I gather biwiring is a waste of time as it makes no difference.
Thank You
http://www.marantz.co.uk/DocumentMaster/master/PM6005N_ENG_CD-ROM_UG_v00...
Look at page 17
The only difference is you spend more on cables :)
Honestly though whenever I have tried it I could discern no difference whatsoever. Bi-amping is a different matter.
MajorFubar
690
6
Most amps won't care whether you bi-wire from separate terminals or from the same ones. The terminals are connected in parallel to the same outputs on the circuit board with switches or relays to turn them on or off. So which you choose won't make any difference. That doesn't include amps which have bi-amping functions built in for this purpose, such as the Marantz MCR610
busb
83
Al ears said:
Thank You
Look at page 17
Although I've had a good experience with bi-wiring a pair of Celestion SL6s many years ago, it actually made the SQ worse with a pair of Totem Arros. My current speakers only have two terminals so any angst regarding bi-wiring is taken out of my hands! As for cost, many dealers will suggest you spend whatever budget you have decided apon on single runs!
Irwan Kasman said:
Hey, Thanks for your replies, really helped me out, save me a bunch on unnecessary cables and banana plug future purchase.
So Im guessing the reason my speakers has 4 connectors is for Bi-Amplifying then...
No, it's there to drive a second set of speakers in, say, another room. Bi- amplifying requires two amplifiers.
Al ears said:
Thank You
Look at page 17
Yup, bi-wiring is a con.
Thompsonuxb
129
Not sure if your kit will appreciate bi-wiring if the truth be told, but it's something that belongs on anyone interested in hifi 'to do' list.....at least once.
Like comparing interconnects or digital v optical inputs on your amp outputs on the source.
Don't take the word of deaf folk - try it and draw your own conclusion.
Do use both sets of speaker terminals on your amp - there are various configurations you can use.
Enjoy your toys....... :)
I was wondering about the connections on the speakers itself, the ones that's connected by the jumper bar. Unless you're telling me I can connect to a second pair of speakers from my first pair
Sorry no, I misread your post and was referring to the connections on the back of the amp. You are correct terminals on back of speakers are jumpered-up for single cable run and separated for either bi-wire or bi-amping.
Irwan Kasman said:
Thanks for all the replies. I've done a bit of research, and a few of them said, that chaging the manufacturer's jumper bar to a little snippit of your speaker cable is the best way to go.
Don't let me stop you wasting money. If you can cut a small amount off your existing cables to try then do it but I would go spending a fortune on ready manufactured and terminated lengths.
Concentrate more on the music, it is after all why you bought your system.
Vladimir
220
7
TrevC
Al ears said:
TrevC said:
I'll take deaf over daft every time.
Once you get to the point where speaker cables have negligible losses you can't really achieve any more by doubling up on them.
Wrong again TrevC, I'll take daft and still be able to enjoy the music rather than deaf and not.
I still enjoy music and I'm not deaf or daft.
TrevC said:
Quite possibly, I couldn't say, but if you care to read my post again you will find that I stated if you are deaf you wouldn't be able to enjoy the music.
Benedict_Arnold
661
One thing you could try is removing those horrible brass jumpers and getting your local hifi shoppe to make you up some jumpers out of the same (hoepfully good) speaker wire as your main runs. You get some of the benefits of bi-wring, get rid of those horrible brass jumpers and don't spend as much as on full bi-wire runs.
Oh, and don't completely remove those brass jumpers. To avoid loosing them, just loosen the terminals, rotate one end clear of one terminal so it's not connecting and re-tighten the terminals.
TrevC
More nonsense. The links are fine left in place.
For once I agree with you TrevC. Why would you replace something that the manufacturer deems perfectly acceptable, and they presumably test the speakers with in place, for a piece of wire? More expense? It's not going to improve th sound.
Edbo2
15
I biwired a pair of JPW AP2s and did not like the sound. The treble was more prominent and bass fuller which made the midrange sound recessed and in the background.
