- Aug 10, 2019
- 2,556
- 5
- 0
Hello everyone. First sorry for my bad English.
The reason for reporting is problem with my philips series 9. In fact, I bought a model 42pfl9603d, which occasionally whew turn on would not give image. Tone would be included and could change channels normally, but no trace of the image. Image to appear when excluded, and again included television (some kind of reset?). Because of this, the TV was in the service twice. The first was replaced some part, and then the entire display. The problem always returned. Then they replace my tv to the 9703 model, which worked normally three months, to the same problem appeared on it. Means the same as the 9603, turn on TV, no picture, the tone goes and can change channels. Then turn off and on a TV, and everything works normally ... To note that the TV is not attached any other device and that this problem does not occur so often, but maybe 1-2 a month.
What's this all about? Is it possible that this is normal behavior sets, and the service it did not know or I just have no luck? Not to mention remote, with their wheel to navigate through menus "jumps and do what they want."
Does anyone can help me their advice, because I no longer know what to do?
