The dreaded ‘what headphone DAC?’ question
Revolutions
Seeing as I’ve got two pairs of semi-decent headphones & my preamp doesn’t have headphone out, I think Black Friday would be a good time to explore this absolutely terrifying looking rabbit hole.
With so many brands, each having multiple units, the choice paralysis is astounding. And there really seems to be little information around direct comparisons when it comes to sound.
My plan is to keep it simple, and I’ve got a shortlist of 2 units: Topping DX3 Pro+ or FiiO K11 R2R
Still, I thought it prudent to throw it out it here for any suggestions from the streamers. I’m well-aware that I know little, and just want to check I’ve not made an error in judgment for my criteria: cheap, simple, sounds great.
abacus
Make sure whichever you choose is compatible with your headphones, as some only work best with either low or high impedance headphones, however if you go for an upmarket (And expensive) unit than they will normally do both.
Bill
Jasonovich
Hifiman Store are doing some great deals right now, their EF500 R2R headphone DAC is a real bargain and you can get directly from them or AliExpress.
The EF400 R2R headphone with the more conventional format, is also another option see reviews below. I believe Hifiman store selling cheap on eBay and AliExpress see links below.
https://www.bing.com/aclk?ld=e8IGNJ2mMzChJEo0foyqaQXjVUCUzQsNSDIm2lxTRKG3WQaCXAWmjR56gQF6QhoMtB7yZ4HOTt-Sgwow7ijRhZKx8YB-AJDGLjk_6YuvjVz6gk-BsJPuSD7I8iUeE2mVXMDWwOSkhhvtq5P4G_OaNQbJ-9Fibqf3jb0fBcwfo_95GxqnKpGj8_W9L6_7qiUk1Ox-PcZg&u=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&rlid=57689c5f3d2517dcec88fb1b6d7872bb&ntb=1&ntb=1
I also like the FiiO. It has the excellent K9 headphone DAC amp and has more features than the Hifiman - comes with Bluetooth - see link below :)
The Exploration version has this glass panel at a slightly higher price - pretty neat!
Also I'm very happy with my XDUOO TA-66 tube headphone amp, doesn't have built in DAC but the sound is so lush and full of tubey loveliness. You would require high Ohms headphones for OTL tube amps, >60ohms. Sounds even better when you tube roll with high quality tubes :)
Gray
Just had a quick look at those.
One thing's for sure, you'll be getting great value with either.
I paid more for a Topping A50S and that's purely an amp (you're getting a lot with that DX3).
Not sure how volume is done on the DX3, but I see the Fiio makes the point that it has electronic volume control - which means no chance of tracking error and possibly greater long-term longevity.
And it's an R2R DAC, which is desirable to some people 😍
Some might say your best option (if possible) is to get both, try, then return the one you like the least.
That always seems a bit of a dodgy practise, but if the retailer offers it......
