Hi all,
A while back i was given a 5.1 system for my home it's a "Samsung kit AV HT-D355" now i know it's nothing speacial although i do like the sound the subwoofer is able to give and the several options the receiver/amp/dvd player is able to give, my problem lies with the speakers mainly the front ones, they have a very annoying noise when high they playing high frequency sound, this noise gets worse as you up the volume and is starts at a rather low volume, my guess is that this noise comes from the design itself.
I really enjoy listening to music and i use this system as my music player as well so what i'd like to do is swap the two front speakers with a new set however i don't know if it's possible technicly, the new set i'd like to put in would be a par of mordaunt short aviano 1xr.
My question is can i swap them? The amp spec say it's output is "51Wattsx2(3 Ohms)" and the speakers are rated at 15-100w but at "8 ohm compatible" this last info was taken out from their website.
Also what can i expect to happen in terms of sound? and will they work nicely with the remaining speakers when watching a movie?
info on the 5.1 can be found on this link: "here" on page 32 and 33
the speakers info is "here"
thanks
thanks
