- Aug 10, 2019
- 2,556
- 5
- 0
It has been some time since I purchased a new TV and DVD recorder so I`m completely out of touch. I have spent the past few months boning up on HD, HD ready, FREEVIEW, FREESAT, 100 hertz compared to 50 hertz Reading manufacturers specs and asking sales staff seems to add to the confusion, however I`m starting to see a small *** of light at the end of this technological tunnel and have actually made a decision that it will be a 32" screen ! Are my conclusions correct ?
Most manufacturers offer Freeview and HD ready sets. To obtain Freesat I would need to purchase an addition piece of kit and have a sat dish fitted. John Lewis currently have on offer a Panasonic TX32LZD81 with built in Freesat HD for £899 and when purchased together with the Panasonic DMR EX 768-K DVD recorder with 160 GB Hard Drive you get the latter for £99, a saving of some £130. As I understand it the advantage of Freesat is not so much the extra channels available but the fact you can receive HD transmitions.
Just when I thought I had a grasp of the subject I started to read a number of blogs / reports in WHAT HI FI and now I`m not so sure I fully understand. I am starting to get the impression that I would be throwing my hard earned cash away on Freesat and HD as on a 32" screen it makes no discernible difference on picture quality. In which case would I be better off purchasing the 32" Sony recently reported as the WHAT HI FI best buy which comes across as being a much better set? If I`m right any suggestions on a compatible DVD player.
I look forward to hearing your views.
